FairOaksStudio Posted Wednesday at 05:10 AM Share Posted Wednesday at 05:10 AM I am having some troubles and have looked everywhere online for a solution but can't seem to find one. I send my elevations and cross sections to layout and the line weights look fine to me. I go to print to PDF and suddenly some of the elevations line weights are much thicker than before. Seems to be very random as some elevation lines are normal still. I haven't touched anything but received an error "#272032247 - The line weight scale in your layout is not the same as in the view being sent to layout. As a result, line weights in that view will not be correct. Line weight scale can set in the Drawing Sheet Setup dialog." so something must have happened on my end. Any help would be much appreciated! I am desperate Note: I did have to remove the program and reinstall it a few days ago. Link to comment Share on other sites More sharing options...
mtldesigns Posted Wednesday at 01:41 PM Share Posted Wednesday at 01:41 PM 8 hours ago, FairOaksStudio said: line weights are much thicker than before When your in the plan mode or a section view (or even in layout), turn on the "Line Weights" and you should see what it will look like in the layout views. This way, if they appear to thick or thin, you can adjust accordingly. Link to comment Share on other sites More sharing options...
MoeGia Posted Wednesday at 01:49 PM Share Posted Wednesday at 01:49 PM The error message is telling you that the view you sent to layout is not set up correctly. Open the icon below the one Michael circled in the plan and the layout. Make sure they are both set to the same the same line weights; mine are 100mm. If they are not set the same, you'll get that message. Then open the problem view and review the line weight and the same to be sure they are correct. Link to comment Share on other sites More sharing options...
