PitMan71 Posted January 6, 2025 Share Posted January 6, 2025 All... Newbie here.... What is the best way to create an attic dormer? I have a plan i am working on that has two decorative dormers over the front porch into the attic. When i use the dormer tool it complains about a wall being in the way, which I guess its referring to the wall separating the porch and living space. That wall does not even go into the attic so I am not sure what the issue is. Thanks in advance for any tips on this. Shane Link to comment Share on other sites More sharing options...
PitMan71 Posted January 6, 2025 Author Share Posted January 6, 2025 This is the roof over the porch where i want the dormers. Link to comment Share on other sites More sharing options...
GeneDavis Posted January 6, 2025 Share Posted January 6, 2025 Plop one where it will model OK, explode it, then select all of it and move it where you want. Delete whatever hole in roof it generated. Link to comment Share on other sites More sharing options...
ericepv Posted January 6, 2025 Share Posted January 6, 2025 Auto dormers work well for this application... https://www.chiefarchitect.com/support/article/KB-00648/creating-an-automatic-dormer.html As Gene mentioned above, you may need to modify it to fit the space. Link to comment Share on other sites More sharing options...
PitMan71 Posted January 6, 2025 Author Share Posted January 6, 2025 Thanks guys. i will try these options. Shane Link to comment Share on other sites More sharing options...
