KarenLF Posted 15 hours ago Share Posted 15 hours ago Hello, My drawing has an additional border of some sort around it. When I click on it, an highlight it, it shows in the "Rooms" layer, but when I uncheck that layer, it still shows. Also I cannot delete it. I did not draw this, I have never come across this and I don't want it on my drawing. What is it and how do I get rid of it? Link to comment Share on other sites More sharing options...
ericepv Posted 15 hours ago Share Posted 15 hours ago Is the 'Rooms' layer unlocked? Link to comment Share on other sites More sharing options...
DBCooper Posted 14 hours ago Share Posted 14 hours ago It just looks like you selected the "exterior room". It's always there (as long as you made a closed box with walls), even if the layer is turned off, but it shouldn't be noticeable unless you have selected it by clicking near an exterior wall. It should go away if you select something else or just hit escape. If it doesn't go away, then something else must be going on and you should post the plan. The only thing locking the layer will do is make it so you can't select it. Turning off the rooms layer might cause other problems too. Link to comment Share on other sites More sharing options...
