annahart12 Posted December 8, 2024 Share Posted December 8, 2024 Does anyone know how to get rid of these crazy reflections? I can't seem to get rid of them and they still appear when changing sunlight, toggling the reflections, and changing the brightness of the lights. It reflects on materials like wood too. Any help is appreciated, thanks! Using Chief Architect 16 Link to comment Share on other sites More sharing options...
Michael_Gia Posted December 9, 2024 Share Posted December 9, 2024 Change sun intensity to 7,000 You probably have it set to something like, daytime 100,000. Also, don’t use a sky as a background. Experiment with a more subdued background that’s more cloudy. Link to comment Share on other sites More sharing options...
DBCooper Posted December 9, 2024 Share Posted December 9, 2024 Could be the sun, or it could be some other light. The lit areas look a lot like a super bright spot light with those curved edges. Check the adjust lights dialog to see if anything is in the list that doesn't make sense. If that doesn't help, then post the plan. Link to comment Share on other sites More sharing options...
DeLayDesign Posted December 10, 2024 Share Posted December 10, 2024 Looks like your light fixtures. Check to see what the bulb intensities are - but also use the 'material adjuster' to see what the 'lighting white' material intensity is set to. Lastly - when you go to do PBRs change your internal Daytime Backdrop Intensity low. I do 500. (Exterior, I do 35,000) Link to comment Share on other sites More sharing options...
MaryAnne2017 Posted January 9, 2025 Share Posted January 9, 2025 annahart12: I have the same issue. Started as soon as I downloaded version 16. DId anything here help you? Link to comment Share on other sites More sharing options...
