Adam_Gibson Posted November 11, 2024 Share Posted November 11, 2024 Looking at past threads, this topic has come up repeatedly. Since it's been a while, I'm asking anew: Is there a setting that will cause a backdrop to NOT color a scene? I can do it with images, or in Photoshop, but has Chief implemented a button that I don't know about to fix this? The attached scene is entirely too green when a forest backdrop is deployed. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 11, 2024 Share Posted November 11, 2024 You can of course use no background or you can choose a different background that creates the effect that you want or you can adjust the intensity of the sunlight which reduces the amount of glare coming through in the windows. DJP Link to comment Share on other sites More sharing options...
Adam_Gibson Posted November 11, 2024 Author Share Posted November 11, 2024 Hi David. I'm aware of those options, but they are workarounds. If I want a green forest background, the inside rooms are tinted green, unlike in real life or photography. Thank you! Link to comment Share on other sites More sharing options...
MarkMc Posted November 11, 2024 Share Posted November 11, 2024 Turning down the Daytime Backdrop intensity usually helps, sometimes also turn down the sun. Link to comment Share on other sites More sharing options...
Adam_Gibson Posted November 11, 2024 Author Share Posted November 11, 2024 I'll give that a try. Link to comment Share on other sites More sharing options...
