decorators3 Posted November 8 Share Posted November 8 (edited) Hi the DENOISE TOOL SEEMS TO BE FROZEN.. ANY SUGGESTIONS. When I open the plan. the saved cameras are there but frozen in PBR-RT and I cannot make any adjustments. I can change the renderings to standard and any other option but when I go back to PBR-RT the image is frozen - I can't make any adjustments to the rendering even the material tool is not visible Edited November 10 by decorators3 IMAGE WASNT ATTACHED and more info Link to comment Share on other sites More sharing options...
scottharris Posted November 9 Share Posted November 9 Is your camera a PBR-RT camera? Denoise only applies in that type of view. Link to comment Share on other sites More sharing options...
decorators3 Posted November 9 Author Share Posted November 9 8 hours ago, scottharris said: Is your camera a PBR-RT camera? Denoise only applies in that type of view. It was in PBR-TR and working great now it doesn't even show on the tool bar. the attached images shows the tool bar in plan mode and then on PBR-RT .. maybe I have to reach out to technical support Link to comment Share on other sites More sharing options...
Renerabbitt Posted November 12 Share Posted November 12 On 11/8/2024 at 3:48 PM, decorators3 said: Hi the DENOISE TOOL SEEMS TO BE FROZEN.. ANY SUGGESTIONS. When I open the plan. the saved cameras are there but frozen in PBR-RT and I cannot make any adjustments. I can change the renderings to standard and any other option but when I go back to PBR-RT the image is frozen - I can't make any adjustments to the rendering even the material tool is not visible you cannot denoise a view that is already denoised Link to comment Share on other sites More sharing options...
decorators3 Posted November 12 Author Share Posted November 12 1 minute ago, Renerabbitt said: you cannot denoise a view that is already denoised thanks I figured it out after a while ... Link to comment Share on other sites More sharing options...
