DENOISETOOL PALLETTE
decorators3
Hi
the DENOISE TOOL SEEMS TO BE FROZEN.. ANY SUGGESTIONS.  When I open the plan.  the saved cameras are there but frozen in PBR-RT and I cannot make any adjustments.  I can change the renderings to standard and any other option but when I go back to PBR-RT the image is frozen -  I can't  make any adjustments to the rendering even the material  tool is not visible
Edited by decorators3
IMAGE WASNT ATTACHED and more info
8 hours ago, scottharris said:
Is your camera a PBR-RT camera?  Denoise only applies in that type of view.
It was in PBR-TR and working great now it doesn't even show on the tool bar.  the attached images shows the  tool bar  in plan mode and then on PBR-RT .. maybe I have to reach out to technical support
On 11/8/2024 at 3:48 PM, decorators3 said:
Hi
you cannot denoise a view that is already denoised
