cbucks Posted October 30 Share Posted October 30 I have a door opening (using a door opening) because I want a drop concrete header. Is there a way I can replace the door with a railing and keep the opening in tact? The other thought was to make an opening an add a Juliet balcony however the door jam is over 12" so I have plenty of space to put a railing in between the opening. Link to comment Share on other sites More sharing options...
Gawdzira Posted October 30 Share Posted October 30 If your opening looks how you want it to look and you want a railing in the opening that is some sort of scroll/ironwork Juliet Balcony type thing- it might be easiest to grab the balcony railing section you want, export it as symbol (make it Millwork) and then just place it in the opening. Link to comment Share on other sites More sharing options...
SHCanada2 Posted October 30 Share Posted October 30 there are also a couple ugly juliet balconies in the exterior accessories??? catalog Link to comment Share on other sites More sharing options...
cbucks Posted October 31 Author Share Posted October 31 On 10/30/2024 at 10:18 AM, Gawdzira said: If your opening looks how you want it to look and you want a railing in the opening that is some sort of scroll/ironwork Juliet Balcony type thing- it might be easiest to grab the balcony railing section you want, export it as symbol (make it Millwork) and then just place it in the opening. Thanks that worked great! Link to comment Share on other sites More sharing options...
