BrianMSmith Posted October 25, 2024 Share Posted October 25, 2024 Hello. VERY new to Chief (3 weeks at the time of this post) and I couldn't find this answer by searching this site and others, or in the Help file. Issue #1: When I create a window schedule, I get the desired results. All 3050SH windows are grouped with the number "W01". BUT... My plan view shows each individual window with a different "W0#" I would like all the identical windows on my plan to show the same callout. See below. Issue #2: Related to the above I am sure... My schedule calls out "W02" as a 3050FX which is correct, but the plan has a callout of "W03". How can I get my schedule and plan callouts to align? Thank you in advance for your patience with this new guy. Link to comment Share on other sites More sharing options...
tundra_dweller Posted October 25, 2024 Share Posted October 25, 2024 If you have more than one window schedule for whatever reason, you could be seeing the label from the other schedule overlaying the label you want to see. If you post the plan someone could probably figure it out in quick time. Link to comment Share on other sites More sharing options...
DBCooper Posted October 26, 2024 Share Posted October 26, 2024 In your picture, your schedule only has two schedule numbers listed (W01 & W02), but your plan has a bunch of other schedule callouts. Like Brett, I would bet that you have another schedule somewhere. Select the window in your plan with the W03 and then use the "find schedule from object" tool to find it. If that doesn't help you solve the problem, then you should probably post the plan. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 26, 2024 Share Posted October 26, 2024 The Window Schedule will always show a separate line when any column isn't exactly the same. W02 is single hung W03 if fixed glass The picture, label and description are all diferent so that's why they are not the same. Link to comment Share on other sites More sharing options...
BrianMSmith Posted October 28, 2024 Author Share Posted October 28, 2024 Thanks all! There was a 2nd hidden window schedule. Deleted them both and recreated and presto! Link to comment Share on other sites More sharing options...
