HumbleChief Posted March 18, 2015 Share Posted March 18, 2015 If you're getting tired of these please let me know. http://www.screencast.com/t/7CvFFU5Y3m7T Link to comment Share on other sites More sharing options...
Bill_Emery Posted March 18, 2015 Share Posted March 18, 2015 I think it would be a good idea to post the plan. Joe has a good strategy in working from the top down. When I have a problem similar to what you're experiencing, I will pull the ends of exterior walls back from the exterior to lose room definitions, as a way to isolate the problem. Link to comment Share on other sites More sharing options...
HumbleChief Posted March 18, 2015 Author Share Posted March 18, 2015 Thanks for the advice Bill. I got it figured out and truly mean it when I say I do not know what I did. Just thrashed through each and every room with each and every structure tab till it worked. Even though I set the defaults for the second floor as wood framed joists I ended up with monolithic slab floors and the defaults were all over the place. I think I just started clicking defaults for everything in every room until I beat it into submission. User error? Probably but this one just went wonky at a certain stage and was hard to retrieve. Again thanks for the reply and advice. Link to comment Share on other sites More sharing options...
chief58 Posted March 18, 2015 Share Posted March 18, 2015 If you're getting tired of these please let me know. http://www.screencast.com/t/7CvFFU5Y3m7T Larry always enjoy your vids I also have problems with this sometimes but eventually figure it out but with to much time taken Link to comment Share on other sites More sharing options...
Jay_on_Cape Posted March 18, 2015 Share Posted March 18, 2015 Larry, Also check the room label name on the general tab that I didn't see in your video. If you had checked "porch" or "garage" for room name it would convert it to a cement floor. Link to comment Share on other sites More sharing options...
HumbleChief Posted March 18, 2015 Author Share Posted March 18, 2015 Thanks Jay, My defaults are set to unspecified room name. If that changed to a porch or a garage then that's another thing that mysteriously overtook that plan. Link to comment Share on other sites More sharing options...
CJSpud Posted March 18, 2015 Share Posted March 18, 2015 Larry: I will use X Sections to troubleshoot things like that. Sometimes even a 3D full overview is good to look at things on the foundation level ... from the bottom side. I also use the Match Properties > Apply Properties often to get things like that sorted out. I think we've all had the experience you are having with the structure tab and getting floor and ceiling elevations where we want them. Most of the time it is something I didn't do right that is the cause of my grief ... sometimes I think it is gremlins at work. Link to comment Share on other sites More sharing options...
HumbleChief Posted March 18, 2015 Author Share Posted March 18, 2015 Most of the time it is something I didn't do right that is the cause of my grief ... This is probably true but darn I wish I could trace the culprit brain spazz down. Anyway onwards and upwards to bigger and better things. Link to comment Share on other sites More sharing options...
HumbleChief Posted March 18, 2015 Author Share Posted March 18, 2015 Larry, here is a little time saver I do. http://screencast.com/t/yIkcndAsPZrL Thanks very much for the tip Perry - really is appreciated. Link to comment Share on other sites More sharing options...
