westvale Posted October 9 Share Posted October 9 Hello friends, I'm working on small detail work, modeling this end table, and can't figure out the correct text or dimension setting to get these dimensions to an appropriate size - they're huge! Please help. Link to comment Share on other sites More sharing options...
MPDesign Posted October 10 Share Posted October 10 Hi Westvale, Try looking at your "Dimensions, Plan" layer text style. Probably set to 1/4" text style. If you change to 1" text style while you need it and then change back to 1/4" text style. Link to comment Share on other sites More sharing options...
westvale Posted October 11 Author Share Posted October 11 Hi Michael, Thank you for your suggestion, however, I tried that and it didn't work. Link to comment Share on other sites More sharing options...
CharlesVolz Posted October 11 Share Posted October 11 Could be: Minimum Display Size specifies the minimum display size of Temporary Dimensions and Labels, in pixels. For labels, this is the on-screen size and does not affect printed or exported output. Link to comment Share on other sites More sharing options...
