DHerb2014 Posted September 30, 2024 Share Posted September 30, 2024 I'm working on a remodel of a straightforward project. Simple gable roof with an intersecting gable. I've watched several videos trying to learn how to extend the roof over a wood deck, and didn't find anything. That said, please see attached PDF photo of the existing house showing dimensions , 3D Chief renders, and the plan file. I've tried spanning the entire roof and then bringing the wall back, but the siding doesn't continue like the photo shows. Also tried an invisible wall with ceiling above, and that didn't work either. Wanted to reach out to the experts in this group to see how to solve this one. I'm baffled. XYZ FLOOR PLAN X16.planFetching info... XYZ RESIDENCE.pdfFetching info... Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 30, 2024 Share Posted September 30, 2024 Did you try changing the overhang width for that wall. If you do that you also have to set the same eave height check box Link to comment Share on other sites More sharing options...
SHCanada2 Posted October 1, 2024 Share Posted October 1, 2024 attached all auto built. 2 changes made. broke up right wall into two and made the one a gable. Changed the eave width. when building the roof, select per below 1098474939_XYZFLOORPLANX16eave and split wall.planFetching info... Link to comment Share on other sites More sharing options...
DHerb2014 Posted October 1, 2024 Author Share Posted October 1, 2024 Thanks for the replies, but it needs to match the photo, with a 5'-6" flat soffit (ceiling). The siding continues horizontally above the cutaway. What's really tricky are the eaves that match each other with this overhang. Link to comment Share on other sites More sharing options...
mtldesigns Posted October 1, 2024 Share Posted October 1, 2024 On 10/1/2024 at 12:15 AM, DHerb2014 said: with a 5'-6" flat soffit (ceiling) Expand See if this gets you in the right direction. 1098474939_XYZFLOORPLANX16 mtl.planFetching info... Link to comment Share on other sites More sharing options...
DHerb2014 Posted October 2, 2024 Author Share Posted October 2, 2024 Michael, thanks again for your invaluable help on this one. Just finished the render and wanted to post it. Here are the before and after shots. 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted October 2, 2024 Share Posted October 2, 2024 did you get it to work with all auto roofs? ..I always like a game of spot the differences . your heel height looks too high or main floor ceiling looks too high as the distance from top of window to peak looks larger. ...can also see it for the space above the windows on the left Link to comment Share on other sites More sharing options...
DHerb2014 Posted October 2, 2024 Author Share Posted October 2, 2024 Correct. I didn't measure the existing house, and just took a couple of photos. Had to rely on scaling with Bluebeam. This was done more to show the homeowner what her "curb appeal" could look like for an AirBnB like she wants to start. She loves it! Link to comment Share on other sites More sharing options...
mtldesigns Posted October 9, 2024 Share Posted October 9, 2024 On 10/2/2024 at 4:52 AM, DHerb2014 said: Michael, thanks again for your invaluable help on this one. Expand You're welcome David. This looks great! Great job my friend. Link to comment Share on other sites More sharing options...
DHerb2014 Posted October 9, 2024 Author Share Posted October 9, 2024 Thanks again Michael for your help. Link to comment Share on other sites More sharing options...
