decorators3 Posted 13 hours ago Share Posted 13 hours ago Hi How can I easily( joking!!!!) create various terrain areas,, such as what is attached. I've tried but the stalagmites go off the grade. I've done walkout basements before but for some reason this one seems to allude me. is it just me trying too many times with the same results any suggestions welcome Levina 17 kimble.pdf Link to comment Share on other sites More sharing options...
DBCooper Posted 11 hours ago Share Posted 11 hours ago Try using elevation regions. I find they are way easier than using elevation points and lines. Link to comment Share on other sites More sharing options...
decorators3 Posted 10 hours ago Author Share Posted 10 hours ago Yes I think thats the way to go thanks Link to comment Share on other sites More sharing options...
DeLayDesign Posted 10 hours ago Share Posted 10 hours ago 2 hours ago, decorators3 said: Hi How can I easily( joking!!!!) create various terrain areas,, such as what is attached. I've tried but the stalagmites go off the grade. I've done walkout basements before but for some reason this one seems to allude me. is it just me trying too many times with the same results any suggestions welcome Levina 17 kimble.pdf 777.86 kB · 22 downloads I think the way I @DBCooperdoes it is similar to how I do. I use the box region and mark them 'flat interior' in the areas I need the terrain to slope. For example, the box at the front door of a home might be 0" elevations (flat interior) but the back of the home is a walk-out basement; that box might be -96" (flat interior) Link to comment Share on other sites More sharing options...
