crossandclark Posted September 23, 2024 Share Posted September 23, 2024 Has anyone had any issues with the upgrade to X16 causing standard renderings to look washed out? I tried lowering the lumens on all the recessed lights and that didn't help. Initially, only some of the lights were on (not washed out, but missing lights), so I went into default settings for the camera view, and changed it from "max lights" to "Light set - default light set". Now all the lights are on, but it looks like a photo with an exposure that is way too high. We do demo renderings live with clients, so I need to easily pull new camera views and not go thorugh a bunch of settings every time to adjust the lights. All the setting from X15 have been copied over to X16 and I never had this issue before. Help! Link to comment Share on other sites More sharing options...
scottharris Posted September 24, 2024 Share Posted September 24, 2024 Can you post a plan with a saved camera so we can look at your settings? Link to comment Share on other sites More sharing options...
Michael_Gia Posted September 24, 2024 Share Posted September 24, 2024 8 hours ago, crossandclark said: Has anyone had any issues with the upgrade to X16 causing standard renderings to look washed out? I had this at first. I lowered the sunlight to 7000 from the 70,000 I used to have it at before X16. I also use a less bright background now as well. Link to comment Share on other sites More sharing options...
crossandclark Posted September 24, 2024 Author Share Posted September 24, 2024 13 hours ago, scottharris said: Can you post a plan with a saved camera so we can look at your settings? This was a huge file, so I deleted the 2nd floor, landscaping, and most of the 1st floor. The kitchen is the main area showing washed out, so it is a good representation of the issue. In order for the lights to be turned on, I changed the floor camera to the default light set. The other issue I am having is how slow this makes the file since it has ALL the lights on in the model (whole model is an 8k sf home). But if I adjust the number of max lights to 50+, it doesn't keep all the lights on in the room I want to show, it randomly selects them. In X15 I had this set to max 8, but somehow they all still came on. My understanding was that this only affected the ray trace renderings, but it seems that is not the case, at least now in X16? Thanks for your help with this issue. Lighting sample plan.zip Link to comment Share on other sites More sharing options...
Solution scottharris Posted September 25, 2024 Solution Share Posted September 25, 2024 For a Standard render view, here are a few settings you might consider adjusting; you can see this in an updated plan attached; see the Camera “Kitchen – Std” -create a light set for only the lights you want on; in your example I created a ‘kitchen’ light set. The more lights the brighter and slower your scene will be since it’s an open design -turn off reflections – they can be expensive and only for mirrors -I changed the lights from point lights to spot lights; and adjusted the lumens from 1200 to 850 – you could go lower. I made a few other light adjustments on your can lights; you can open one and review. -I adjusted the ambient light from 100 to 20 In one of the attached examples, there’s a .25 line under ‘hand drawn lines on top’ setting Note, in the plan you attached, there are several missing materials, so, it probably will not look as good as your original plan Lighting sample2.zip Link to comment Share on other sites More sharing options...
DeLayDesign Posted September 27, 2024 Share Posted September 27, 2024 On 9/23/2024 at 5:42 PM, crossandclark said: Has anyone had any issues with the upgrade to X16 causing standard renderings to look washed out? I tried lowering the lumens on all the recessed lights and that didn't help. Initially, only some of the lights were on (not washed out, but missing lights), so I went into default settings for the camera view, and changed it from "max lights" to "Light set - default light set". Now all the lights are on, but it looks like a photo with an exposure that is way too high. We do demo renderings live with clients, so I need to easily pull new camera views and not go thorugh a bunch of settings every time to adjust the lights. All the setting from X15 have been copied over to X16 and I never had this issue before. Help! When doing a PBR; Check your Daytime Backdrop intensity. For interiors I change mine to 500, but for exterior views you may want to go with 35,000 - 40,000 Link to comment Share on other sites More sharing options...
crossandclark Posted September 27, 2024 Author Share Posted September 27, 2024 On 9/24/2024 at 8:34 PM, scottharris said: For a Standard render view, here are a few settings you might consider adjusting; you can see this in an updated plan attached; see the Camera “Kitchen – Std” -create a light set for only the lights you want on; in your example I created a ‘kitchen’ light set. The more lights the brighter and slower your scene will be since it’s an open design -turn off reflections – they can be expensive and only for mirrors -I changed the lights from point lights to spot lights; and adjusted the lumens from 1200 to 850 – you could go lower. I made a few other light adjustments on your can lights; you can open one and review. -I adjusted the ambient light from 100 to 20 In one of the attached examples, there’s a .25 line under ‘hand drawn lines on top’ setting Note, in the plan you attached, there are several missing materials, so, it probably will not look as good as your original plan Lighting sample2.zip 9.5 MB · 17 downloads This is very helpful, thank you! Link to comment Share on other sites More sharing options...
