lhwalker Posted September 10, 2024 Share Posted September 10, 2024 WHEN EXPORTING A 3D MODEL - FOR SOME RESON IT STOPPED EXPORTING THE SECOND FLOOR WAS WORKING FINE LAST WEEK, HAD SOME REVISION DONE TO THE SECOND FLOOR THIS WEEK BY AN EMPLOYEE NOW IT WONT EXPORT SECOND FLOOR IT GENERATES MODEL FINE WITHIN CHIEF, ANY SUGGESTIONS? Link to comment Share on other sites More sharing options...
DBCooper Posted September 10, 2024 Share Posted September 10, 2024 Are you in a floor or full overview? Do you have any other camera views open? As far as I know, it will always export whatever you see on the screen. So if it looks good on the screen, it should match. Link to comment Share on other sites More sharing options...
lhwalker Posted September 10, 2024 Author Share Posted September 10, 2024 I'm in a normal full 3d overview which is where I normally export from. I just wndered if there was an export setting somewhere that made sure all layers were being exported, it's weird because its just not exporting the second floor, if move the entire roof to first floor it will export the roof, if i move roof to second floor not only will it not export the second floor but no roof either Link to comment Share on other sites More sharing options...
lhwalker Posted September 10, 2024 Author Share Posted September 10, 2024 sorry, not sure where to change it but I'm in premier x16 Link to comment Share on other sites More sharing options...
DBCooper Posted September 11, 2024 Share Posted September 11, 2024 I really can't think of anything else to try because I am pretty sure that it always exports the same thing you see on the screen. You could try posting your plan and then maybe someone else can try exporting to see if they get the same problem. Link to comment Share on other sites More sharing options...
glennw Posted September 11, 2024 Share Posted September 11, 2024 What format are you trying to export to? Link to comment Share on other sites More sharing options...
lhwalker Posted September 11, 2024 Author Share Posted September 11, 2024 I usually do a 3ds but on this plan it has never worked correctly, I have used the 3d dwg model export and it has worked fine up until this week. I'm going to try and copy the plan into a clean chief file and try it again to see if the file is corrupt Link to comment Share on other sites More sharing options...
