Walls, Hatching Layer Question
JKEdmo
Go to solution Solved by BenPalmer,
  • Solution
Search help for "wall hatching" and lots of info...opening line in help below, with more info found within help:
"The Wall Hatching tool can be used to fill wall segments with a single hatch pattern in plan view. To apply wall hatching, select Build> Wall> Wall Hatching, then click on a wall. The hatch pattern covers the entire length and width of the wall segment."
also: https://www.chiefarchitect.com/support/article/KB-00034/adjusting-the-display-of-wall-layers.html
"The "Walls, Hatching" layer is used for wall hatching when the Wall Hatching hatch.png?1721331921 tool is used."
I personally use this for designating interior bearing walls within my plan so I can turn that layer on and off for the various plans I want or don't want to display them on.
