JKEdmo Posted August 20, 2024 Share Posted August 20, 2024 I couldn't find this in Help, but what is this layer used for? Thanks, Jim Link to comment Share on other sites More sharing options...
Solution BenPalmer Posted August 20, 2024 Solution Share Posted August 20, 2024 Search help for "wall hatching" and lots of info...opening line in help below, with more info found within help: "The Wall Hatching tool can be used to fill wall segments with a single hatch pattern in plan view. To apply wall hatching, select Build> Wall> Wall Hatching, then click on a wall. The hatch pattern covers the entire length and width of the wall segment." also: https://www.chiefarchitect.com/support/article/KB-00034/adjusting-the-display-of-wall-layers.html "The "Walls, Hatching" layer is used for wall hatching when the Wall Hatching tool is used." I personally use this for designating interior bearing walls within my plan so I can turn that layer on and off for the various plans I want or don't want to display them on. Link to comment Share on other sites More sharing options...
JKEdmo Posted August 20, 2024 Author Share Posted August 20, 2024 8 minutes ago, BenPalmer said: Search help for "wall hatching" Perfect! Makes sense now. Thanks Ben for taking the time. Jim 1 Link to comment Share on other sites More sharing options...
EsteeChief Posted December 16, 2024 Share Posted December 16, 2024 how can I turn it into solid? THANK YOU Link to comment Share on other sites More sharing options...
BenPalmer Posted December 16, 2024 Share Posted December 16, 2024 The link supplied in previous post covers most of that...following those direction, select the hatching after it has been placed, open it's dialogue box and change the pattern to solid fill and choose desired color. OR before applying the hatching, double click the tool and designate the fill then the subsequent walls you paste it on will have that designation. Link to comment Share on other sites More sharing options...
