Skip_D Posted August 20, 2024 Share Posted August 20, 2024 Hi, I have three issues with the attached plan. I've attached the plan. 1. Roof framing - the rafters re ommitted over a part of the roof. The rafters are showing fine on another part of the same roof plane. 2. Floor blocking is not showing, thought the plywood that sits directly on top of it is showing??? 3. Why is plywood strips showing on top of all the floor joists? Thanks, Skip Townsend - 5.3 - Copy.zipFetching info... Link to comment Share on other sites More sharing options...
Solution DBCooper Posted August 20, 2024 Solution Share Posted August 20, 2024 3. Your OSB is marked as "framing" in the floor structure. Link to comment Share on other sites More sharing options...
Skip_D Posted August 20, 2024 Author Share Posted August 20, 2024 Thank you. Link to comment Share on other sites More sharing options...
DBCooper Posted August 20, 2024 Share Posted August 20, 2024 2. The only floor blocking I could find was down on the foundation. It shows on the plan view and in the framing view. A handy tool is to select the layer you want in the ALDO and use the "find objects" tool. It shows you where things are and lets you select them. Link to comment Share on other sites More sharing options...
TeaTime Posted August 20, 2024 Share Posted August 20, 2024 On 8/20/2024 at 7:14 PM, Skip_D said: the rafters re ommitted over a part of the roof Expand Turned on Auto Rebuild Framing, aligned the gable eaves on that side. Seems fine now. Link to comment Share on other sites More sharing options...
Skip_D Posted August 20, 2024 Author Share Posted August 20, 2024 Okay, thanks. That seemed to work for me but not the first time; I had to keep moving the roof on the front and back in & out. Finally it worked. Weird. thanks, Skip Link to comment Share on other sites More sharing options...
