Changing Electrical Font Defaults in X15 / X16
DHerb2014
I've been trying to find out (unsuccessfully) how to change font type and size for electrical symbols, particularly the AFCI outlet.
By default, AFCI has a very small font height and is City Blueprint. I'd like to change it to a 3" high, Arial Narrow font for example. Please see attached for example.
Try this:
 - Select the outlet
 - Use the "edit cad block" tool
 - Select the text and then open the dialog
 - Go the "text style" page and make your changes
 - Click Ok
 - Close the cad block window and save your changes
 - Update all the instances of the block
Now if you want to use this for all of your plans, save your modified outlet to your user library.
Thanks DBC. Is there a way to make this a default setting or do we have to manually select it each time we use it? Wish CA would open these settings up for us.
AFCI has too small of a font size and uses City Blueprint.  A double negative.
