Turret Design Help Please
HumbleChief
Go to solution Solved by JKEdmo,
I haven't designed a turret entry for a while and am a bit stumped. I can get close to the attached pics (no need for the extra detail) but Chief is building the upper section a bit weird with no stucco finish and the arch into the entry seem to be defined by the door with more weird finishes. Would like to create an arched opening with the door behind in a separate wall? Any help greatly appreciated.
Plan below
https://www.dropbox.com/scl/fi/nin6hmyyfsxal3w6s722m/TURRET-1.plan?rlkey=665ifiu26a6mi50aysm688o5q&dl=0
8 minutes ago, para-CAD said:
Those are a pain to frame, too.
We would have the studs at 6" o.c. to help keep the sheetrock from looking segmented.
I don't know about why the upper stucco is missing but I got the door to look a bit better.
https://www.dropbox.com/scl/fi/fren8cgk7pa71ibiug9cc/TURRET-1-para.plan?rlkey=gcvsiwapjpsnntgtguy3nafq3&dl=0
Vary helpful on the door!! I'll see if I can duplicate!
  • Solution
1 hour ago, HumbleChief said:
no stucco finish
Larry,
I was able to get the stucco finish to generate on the upper portion by selecting this:
jim
