HumbleChief Posted August 19, 2024 Share Posted August 19, 2024 I haven't designed a turret entry for a while and am a bit stumped. I can get close to the attached pics (no need for the extra detail) but Chief is building the upper section a bit weird with no stucco finish and the arch into the entry seem to be defined by the door with more weird finishes. Would like to create an arched opening with the door behind in a separate wall? Any help greatly appreciated. Plan below https://www.dropbox.com/scl/fi/nin6hmyyfsxal3w6s722m/TURRET-1.plan?rlkey=665ifiu26a6mi50aysm688o5q&dl=0 Link to comment Share on other sites More sharing options...
para-CAD Posted August 19, 2024 Share Posted August 19, 2024 Those are a pain to frame, too. We would have the studs at 6" o.c. to help keep the sheetrock from looking segmented. I don't know about why the upper stucco is missing but I got the door to look a bit better. https://www.dropbox.com/scl/fi/fren8cgk7pa71ibiug9cc/TURRET-1-para.plan?rlkey=gcvsiwapjpsnntgtguy3nafq3&dl=0 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted August 19, 2024 Author Share Posted August 19, 2024 8 minutes ago, para-CAD said: Those are a pain to frame, too. We would have the studs at 6" o.c. to help keep the sheetrock from looking segmented. I don't know about why the upper stucco is missing but I got the door to look a bit better. https://www.dropbox.com/scl/fi/fren8cgk7pa71ibiug9cc/TURRET-1-para.plan?rlkey=gcvsiwapjpsnntgtguy3nafq3&dl=0 Vary helpful on the door!! I'll see if I can duplicate! Link to comment Share on other sites More sharing options...
Solution JKEdmo Posted August 19, 2024 Solution Share Posted August 19, 2024 1 hour ago, HumbleChief said: no stucco finish Larry, I was able to get the stucco finish to generate on the upper portion by selecting this: jim Link to comment Share on other sites More sharing options...
HumbleChief Posted August 19, 2024 Author Share Posted August 19, 2024 Thanks Jim!! Worked a treat but a bit confusing as the ceiling is already set to 144" and seem like there should be no need to 'balloon through ceiling above' as the ceiling is already 12 ft tall? Oh well. THANKS AGAIN! Link to comment Share on other sites More sharing options...
