westvale Posted August 1, 2024 Share Posted August 1, 2024 Hello fellow CA users, I'm trying to replicate the mulled unit in the first image. I created a door and 3 windows. When I select all 4 items and click "create mulled unit" the warning pops up. Can anyone help me? Link to comment Share on other sites More sharing options...
tundra_dweller Posted August 1, 2024 Share Posted August 1, 2024 Try mulling the door & sidelites together first, then mull that assembly to the transom. 3 Link to comment Share on other sites More sharing options...
JKEdmo Posted August 1, 2024 Share Posted August 1, 2024 12 minutes ago, westvale said: "create mulled unit" the warning pops up I've had that. Try mulling the lower door and the adjacent sidelites together into a sub-unit. Then try mulling that with the transom above. See if that works. Jim Link to comment Share on other sites More sharing options...
westvale Posted August 2, 2024 Author Share Posted August 2, 2024 I tried that and here's what I got. Link to comment Share on other sites More sharing options...
tundra_dweller Posted August 2, 2024 Share Posted August 2, 2024 Looks like your sidelites are a little higher than your door so if you want to mull the transom to the bottom units you'll have to change something to make the sidelites have the same top elevation as the door. I don't remember if the rough opening plays into this, I think it's just the floor-to-top height for each unit that matters. Another thing you could try if you wanted a mulled look is to add a wall material region over that whole area with the edges beyond the openings to whatever width you want your trim to be. The doors and windows will cut the material region and in between them the material region should look like trim. Link to comment Share on other sites More sharing options...
robdyck Posted August 2, 2024 Share Posted August 2, 2024 22 hours ago, westvale said: I'm trying to replicate the mulled unit in the first image. While it works to mull windows and doors, it doesn't always work well. In these situations, I use a fixed door for the windows. You can adjust the dimensions to look similar to the windows and they will mull much nicer. Make sure the side lites have the same top elevation as the door. 1 1 Link to comment Share on other sites More sharing options...
