JamesR Posted July 29, 2024 Share Posted July 29, 2024 Hi folks, I search the forums but didn't find anything specific to electrical devices (there seems to be plenty of info on multiple room labels for example). I'm looking for a way to have several different labels for various electrical devices (switches, outlets, lights, etc) available on different layers and/or plan views. I would like to keep the default label for most of the items (AFCI/GFCI for outlets, single, 3-way for switches) but have other plan-specific labels for each item. The only way I'm thinking I can do it is with text labels that I assign to different layers. That has the drawback of if I move or delete the device, the text label does change. Any ideas for something like this would be appreciated! Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 29, 2024 Share Posted July 29, 2024 1 hour ago, JamesR said: Hi folks, I search the forums but didn't find anything specific to electrical devices (there seems to be plenty of info on multiple room labels for example). I'm looking for a way to have several different labels for various electrical devices (switches, outlets, lights, etc) available on different layers and/or plan views. I would like to keep the default label for most of the items (AFCI/GFCI for outlets, single, 3-way for switches) but have other plan-specific labels for each item. The only way I'm thinking I can do it is with text labels that I assign to different layers. That has the drawback of if I move or delete the device, the text label does change. Any ideas for something like this would be appreciated! This is easy to do with a macro in a label that has a conditional statement that looks at the active layer set of the item. Link to comment Share on other sites More sharing options...
JamesR Posted August 3, 2024 Author Share Posted August 3, 2024 Easy for you I'm sure Rene Is there any examples, or does anyone sell an easy to modify version of it? Thanks, --Jamie Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 3, 2024 Share Posted August 3, 2024 I have a system that I set up about 8 years ago that does exactly what you're looking for. I called it my "Super Label Switches". You just changed which label you wanted to use in any given layer set using a dropdown. Chief has changed some things since then that kinda makes me want to update the system to simplify it a bit though. Shoot me over an email to alaskansons@gmail.com if you'd like to discuss further and we can take it from there. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 5, 2024 Share Posted August 5, 2024 On 8/3/2024 at 10:08 AM, JamesR said: Easy for you I'm sure Rene Is there any examples, or does anyone sell an easy to modify version of it? Thanks, --Jamie When Michael has a system that is applicable then I simply defer to him and promote his product. He's a good hard working guy that builds great systems and is so good to this community so its good to support each other here and give him the floor. If I could bother you though, curiosity has me...what is a use case for this for the electrical symbols? What are you showing on the different plan views? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 5, 2024 Share Posted August 5, 2024 4 hours ago, Renerabbitt said: If I could bother you though, curiosity has me...what is a use case for this for the electrical symbols? What are you showing on the different plan views? I have the same question. Personally, I've copied all the Electrical Symbols to my user Library and made all the editis I want there, including Labels, Layers and Layer Sets. Then I set the Defaults for them. That p[retty much takes care of even the most complex plans. I also have custom Toolbars for Outlets, Switches, Communications & Alarms which use those symbols. 1 Link to comment Share on other sites More sharing options...
JamesR Posted August 10, 2024 Author Share Posted August 10, 2024 Its a bit overboard, but its mainly for low-voltage devices (wall plates, access points, cameras, etc). On the general electrical plan view I just note generically what they are for clarity sake. However, because there can be several wall plates in a room, and several cables ran to each wall plate for example, I have a more detailed plan view that has unique numbering for each device so they can be labeled and identified in the IDF or MDF. And to close the loop, Michael had a great solution for the problem. A+ on communication and follow up. Thanks, --Jamie 1 Link to comment Share on other sites More sharing options...
