DianeP Posted July 21 Share Posted July 21 I have seen some posts where the solution is discussed. It involves the use of shadow boards. Has anyone seen or made a video that would show me how this is accomplished? Link to comment Share on other sites More sharing options...
DBCooper Posted July 21 Share Posted July 21 Sloped how? Your fascia will be sloped on a gable end and you can also set your eaves to be "square cut" instead of "plumb cut" but I am guessing that you want something else. Maybe post a picture of what you are trying to do? 1 Link to comment Share on other sites More sharing options...
tundra_dweller Posted July 21 Share Posted July 21 I'm totally guessing here, but if you are trying to put an angle on your fascia (for example a gable end not having plumb and square cut fascia) I would think you could create a molding profile that is triangle shaped, and sized according to your fascia size and how much of an angle you want on it, then apply that molding profile as a shadow board to whatever roof edges you want it on. I have never done or tried this, but I think it would work, with some trial and error. 1 Link to comment Share on other sites More sharing options...
tundra_dweller Posted July 21 Share Posted July 21 I had to check and make sure this works and it does. I used a frieze molding from the core catalog. 1 Link to comment Share on other sites More sharing options...
DianeP Posted July 23 Author Share Posted July 23 On 7/21/2024 at 10:23 AM, DBCooper said: Sloped how? Your fascia will be sloped on a gable end and you can also set your eaves to be "square cut" instead of "plumb cut" but I am guessing that you want something else. Maybe post a picture of what you are trying to do? Sorry for the delay in response. I think this is what the client is wanting. I will do it this way to show him. I had forgotten this option. Thanks! Link to comment Share on other sites More sharing options...
DianeP Posted July 23 Author Share Posted July 23 On 7/21/2024 at 1:23 PM, tundra_dweller said: I had to check and make sure this works and it does. I used a frieze molding from the core catalog. Thanks Brett, This is more like what I was seeing in the discussions I mentioned. I may have to use something like this if the client isn't happy with the square cut mentioned earlier doesn't work for the client. Link to comment Share on other sites More sharing options...
