sloped facia video?
DianeP
Sloped how?  Your fascia will be sloped on a gable end and you can also set your eaves to be "square cut" instead of "plumb cut" but I am guessing that you want something else.  Maybe post a picture of what you are trying to do?
I'm totally guessing here, but if you are trying to put an angle on your fascia (for example a gable end not having plumb and square cut fascia) I would think you could create a molding profile that is triangle shaped, and sized according to your fascia size and how much of an angle you want on it, then apply that molding profile as a shadow board to whatever roof edges you want it on. I have never done or tried this, but I think it would work, with some trial and error.
Sorry for the delay in response.  I think this is what the client is wanting.  I will do it this way to show him.  I had forgotten this option.  Thanks!
On 7/21/2024 at 1:23 PM, tundra_dweller said:
I had to check and make sure this works and it does. I used a frieze molding from the core catalog.
Thanks Brett, This is more like what I was seeing in the discussions I  mentioned.  I may have to use something like this if the client isn't happy with the square cut mentioned earlier doesn't work for the client.
