westvale Posted July 12, 2024 Share Posted July 12, 2024 Hello friends, I'm trying to draw a pony wall in a shower. The pony wall was drawn as a railing in Chief with glass on top. I need the wall to come beyond the end of the shower tray, where there's a glass wall perpendicular. The pony wall needs to extend past the perpendicular wall but it keeps snapping to it. I can either have it too far past, or not enough, but it won't allow it just a couple inches past. What do I do? You can see in the image that the flange of the shower tray is poking out which I'm trying to fix. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 12, 2024 Share Posted July 12, 2024 A short room divider can sometimes help with this, seen in orange below M. 1 Link to comment Share on other sites More sharing options...
westvale Posted July 18, 2024 Author Share Posted July 18, 2024 I have a room divider for the shower so that I don't have baseboards in the shower. Are you suggesting a second room divider? Link to comment Share on other sites More sharing options...
mtldesigns Posted July 18, 2024 Share Posted July 18, 2024 6 minutes ago, westvale said: I have a room divider for the shower so that I don't have baseboards in the shower HUH? I am not sure I understand why you have this to not have baseboards. If the shower is a room, you can delete baseboards. If its not a room, you can turn off baseboards on a given wall.. And yes to answer your question to Mick.. Use a diver to get that pop out Link to comment Share on other sites More sharing options...
Kbird1 Posted July 18, 2024 Share Posted July 18, 2024 5 minutes ago, westvale said: I have a room divider for the shower so that I don't have baseboards in the shower. Are you suggesting a second room divider? Yes in that case it should work, it is the other RD that is causing it to always snap back. M. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 18, 2024 Share Posted July 18, 2024 1 minute ago, mtldesigns said: HUH? I am not sure I understand why you have this to not have baseboards. In the Shower Michael , not the bathroom , personally I have a Room type made for Showers that does not have BBs by default. M. Link to comment Share on other sites More sharing options...
