Cadwork22 Posted June 30, 2024 Share Posted June 30, 2024 I was advised to use the room floor finish layer, to shut off fills in other parts of the layout. However, this layer doesn't exist. Is there another name? Link to comment Share on other sites More sharing options...
Gawdzira Posted June 30, 2024 Share Posted June 30, 2024 Link to comment Share on other sites More sharing options...
Kbird1 Posted June 30, 2024 Share Posted June 30, 2024 5 hours ago, Cadwork22 said: I was advised to use the room floor finish layer, to shut off fills in other parts of the layout. However, this layer doesn't exist. Is there another name? There is no room floor finish layer you'd have to turn of the Room Layer in Plan View. This can have side effects in some views (eg 3D views) other than Plan View though and it is generally best left on. If this is your SOP then using the Room Polyline Tool and adding a fill to it may work better as you can then add each one to a for eg. Rooms, Color Fills Layer, you can turn on and off as needed. M. Link to comment Share on other sites More sharing options...
