westvale Posted June 26, 2024 Share Posted June 26, 2024 Hello friends, I've built this as a full height cabinet with applied panels. Does anyone know if there's a way to remove these two vertical portions of the cabinet box? Or do I have to build it as a base cabinet, wall cabinet, partitions and a floating shelf? Link to comment Share on other sites More sharing options...
DBCooper Posted June 26, 2024 Share Posted June 26, 2024 You could set the left and right side to "none" but then you would have to place the side partitions manually. Probably a bunch of ways to build this unit and I don't think there is any one in particular that is going to be much better than the others. Link to comment Share on other sites More sharing options...
MarkMc Posted June 26, 2024 Share Posted June 26, 2024 3 hours ago, westvale said: do I have to build it as as the way it would be in real life? That's what I would do but it can be done as a cabinet with a few caveats. As done here what appears to be applied side panels are not the same as you show. These are on the front of the cabinet. That means that the shelf goes beyond the edge to the inside of the cabinet. There are other far more complicated ways to do it with custom door symbols but I would not (and I do a lot of stuff that should not be done How is it getting done IRL? in any case plan attached which might be instructive for something else in the future. Tall but why.zip Link to comment Share on other sites More sharing options...
