Erin-G Posted Tuesday at 05:57 PM Share Posted Tuesday at 05:57 PM Does anyone have experience with phantom cabinets or other items? There is "extra" hardware and countertops showing in my wall elevation view, but I don't know where they are coming from. I moved everything around to see if I could find anything hiding, but I found nothing. I've attached a screenshot so you can see what I'm referring to. There is also something in front of the range that I have no idea what it is. I am using version X12. Any help would be greatly appreciated! Link to comment Share on other sites More sharing options...
Erin-G Posted Tuesday at 06:00 PM Author Share Posted Tuesday at 06:00 PM I also just saw some cabinet hardware in the middle of the range. Link to comment Share on other sites More sharing options...
NRST8TRKR Posted Tuesday at 06:09 PM Share Posted Tuesday at 06:09 PM attach the plan to get help. Link to comment Share on other sites More sharing options...
MMeabrodE Posted Wednesday at 12:43 PM Share Posted Wednesday at 12:43 PM I'm having the same problem. Plus when I delete a cabinet or change size of cabinet the other one still stays. Wont let me add file. Link to comment Share on other sites More sharing options...
DBCooper Posted Wednesday at 03:33 PM Share Posted Wednesday at 03:33 PM Quote Wont let me add file. There is a size limit for files on this forum and most plans will be too big. So do a "save as" and delete everything that isn't related to the problem. Then "zip" the file to compress it and make it smaller. You need to make sure you do this when the plan is not open in Chief or it won't work. As for your problem, I got nothing. Really need to poke around the plan to see what is going on. Link to comment Share on other sites More sharing options...
DBCooper Posted Wednesday at 03:39 PM Share Posted Wednesday at 03:39 PM As for Erin's original problem, the only thing I can think of is that maybe your camera is seeing hardware for cabinets behind your camera instead of what you are looking at? If this is the case, you might just need to move the camera a little bit forward. Link to comment Share on other sites More sharing options...
MarkMc Posted Wednesday at 07:06 PM Share Posted Wednesday at 07:06 PM 6 hours ago, MMeabrodE said: Wont let me add file First try- File, backup entire plan, backup plan files only and send backup files to zip archive. Not usefuil if your textures are needed for answer but otherwise works often. For instance I just used that to upload a file that shows to be 4.71 MB but once backed up without anything was 711KB. If that doesn't get it small enough strip out everything but that room and the one right behind it, everything, then save as, the backup. No point in guessing without a plan file. Link to comment Share on other sites More sharing options...
