Astrigal Posted June 19, 2024 Share Posted June 19, 2024 I'm sure there must be an easy answer to this but it escapes me. When I create a simple pony wall with Siding-6 upper and 8" conc lower it produces this: But I am wanting the face of the concrete to be flush with the face of the sheathing layer. I think I tried all the settings I could see but nothing seems to affect the relationship between the upper and lower walls. Link to comment Share on other sites More sharing options...
JiAngelo Posted June 19, 2024 Share Posted June 19, 2024 In your wall definition on the upper wall move the plywood to inside the main layer. However all exterior dimensions will now be to this plywood, not the stud. Link to comment Share on other sites More sharing options...
DBCooper Posted June 20, 2024 Share Posted June 20, 2024 Open the wall dialog and go the the "wall types" section. Change "align pony wall" to "outer surface". 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 20, 2024 Share Posted June 20, 2024 2 hours ago, DBCooper said: Open the wall dialog and go the the "wall types" section. Change "align pony wall" to "outer surface". but thats aligning to outer surface. They want sheathing layer Link to comment Share on other sites More sharing options...
Astrigal Posted June 20, 2024 Author Share Posted June 20, 2024 @Renerabbitt True. I did want it to align with the sheathing layer. I think I found a work-around (at least until I can discover a better way) If I leave 'outer surface' checked (as @DBCooper has suggested) and create an additional outer layer at thick as the main outer layer, and call it an air gap, and check it off as so, then things line up with the sheathing. Link to comment Share on other sites More sharing options...
