X15: Pony wall display in plan view - how to see only the 8" stemwall
GeneDavis
I've a level 0 walkout basement, which has pony walls at the various walls that are walkout.  The wall makeup is simple, 8" stemwall single layer below, OOB siding-6 above.  I may have modified siding-6 to have 7/16" OSB and 1/2" siding, but what I have is a line I want to get rid of in the plan view.
The line is the one with the 15/16" (OSB plus siding) offset from the stemwall line.  See it in the image from layout, attached.  To the R of wall break for the full height foundation, there is no line, as that wall is not a pony wall.  To the L of the break, you can see the "siding" line.
I want it gone.  Pony wall display in the plan view is set for lower wall only.  And lower wall is, as I said above, single layer 8" concrete stemwall.
17 minutes ago, GeneDavis said:
Thanks, @tundra_dweller, but I tried that and the exterior layers lines are still there.
Hmmm...that's strange. The only other thing I can think of is if your pony wall settings in the default settings are set to something different versus the pony wall settings in the individual walls. I think the individual wall settings will override the default pony walls settings.
