ddaigle Posted June 14, 2024 Share Posted June 14, 2024 Hi There, I recently downloaded the X16 Beta. I noticed today that when I try to export a jpeg of a cross section, that some of the section details (cabinet labels, and outline of structure get shifted, and overlaid. When I Export, I have 'Use Active Window Size' Checked, and nothing else. I've tried playing with these settings, though still have the same result. I've attached a couple of pics. Is anyone else having this problem? Thx! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 14, 2024 Share Posted June 14, 2024 What are you using to export? Why not print to PDF? Link to comment Share on other sites More sharing options...
DBCooper Posted June 16, 2024 Share Posted June 16, 2024 I assume you are just using "file-export picture" directly from the cross section view. I have not seen a problem like this and it is possible that this is related to your video card. Try updating your drivers to see if it magically goes away. If not, then you could try posting the plan to see if anyone else gets the same problem. The other thing you might want to do is report this to tech support. Link to comment Share on other sites More sharing options...
ddaigle Posted June 17, 2024 Author Share Posted June 17, 2024 Yes, I'm using the file-export picture function, and have tested on numerous plans, so it is not plan specific. My video card has not changed, and X15 and prior versions have no issue with this same function. Thanks for the tips though. Perhaps tech support is the way to go. Cheers! Link to comment Share on other sites More sharing options...
StillBlank Posted August 1 Share Posted August 1 (edited) @ddaigle Did you find solution to this? Recently experiencing it myself. Drivers on my pc are cumbersome to update for whatever reason. I will update if i have to but prefer to do it less often and cautiously. Thanks Edit: updated from 572 to version 577 with same results. Edited August 1 by StillBlank added detial that i updated graphics driver and still experience OP's symptoms. Link to comment Share on other sites More sharing options...
