BlueHandle Posted June 9, 2024 Share Posted June 9, 2024 I'm trying to create a greenhouse with visible framing members with polycarbonate over it (which I model as transparent glass). However when I define my Wall Type whatever I specify as the framing layer in the fall forms a solid material instead of just being studs/beams. I've been able to do this before so I know it can be done, but no idea how I did it. I flipped some or other setting and it became solid and is always now solid. I started a new test project but same thing. Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted June 9, 2024 Solution Share Posted June 9, 2024 Hi, you are showing Framing, Wall in your 3D cameras correct ? AND have built the Framing if not on Auto? M. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 9, 2024 Share Posted June 9, 2024 Did you remember to frame the wall ? Link to comment Share on other sites More sharing options...
BlueHandle Posted June 9, 2024 Author Share Posted June 9, 2024 12 minutes ago, Kbird1 said: Hi, you are showing Framing, Wall in your 3D cameras correct ? AND have built the Framing if not on Auto? M. 12 minutes ago, Chopsaw said: Did you remember to frame the wall ? The wall was framed, but kbird1 has it right. My 3D camera view was set to something that didn't show framing. For crying out loud, took me 3 hours of going through every setting and like 5 tutorials on solariums and greenhouses. Stubbornly didn't want to ask because I knew it would be obvious... Thanks! Link to comment Share on other sites More sharing options...
