westvale Posted June 5, 2024 Share Posted June 5, 2024 Hello friends, Does anyone know how to get rid of the light circle produced by these puck lights? I've tried reducing the lumens on the individual light fixture, but it didn't help. I want the light to glow, but not produce a circle below it. Link to comment Share on other sites More sharing options...
Solution DBCooper Posted June 5, 2024 Solution Share Posted June 5, 2024 Try adjusting the "cut off angle" to make the cone shape larger and then increase the "drop off rate" to fade the edges. 1 Link to comment Share on other sites More sharing options...
westvale Posted June 5, 2024 Author Share Posted June 5, 2024 That's better! Took some playing around with the settings as I don't really know how they work exactly. But I got there eventually. Thanks for the tips! Link to comment Share on other sites More sharing options...
Kbird1 Posted June 9, 2024 Share Posted June 9, 2024 The puck light shouldn't shine through the Shelves, if that happens in X16 I'd send it in to be fixed. You can also set the Puck light materials ( glass?) to be emissive on the Properties Tab i( and turn off the light) f you want it to just look like it is On rather than showing pools of light ?, but you could also try a wider angle perhaps eg in the 165 -175° and a much lower drop off rate < 3.0 eg..... = Link to comment Share on other sites More sharing options...
DBCooper Posted June 9, 2024 Share Posted June 9, 2024 Quote The puck light shouldn't shine through the Shelves, if that happens in X16 I'd send it in to be fixed. He has a puck light on each shelf. You can see it better in the first picture he posted. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 9, 2024 Share Posted June 9, 2024 3 minutes ago, DBCooper said: He has a puck light on each shelf. You can see it better in the first picture he posted. Ahhh you are corrected I never enlarged the 1st pic . M. Link to comment Share on other sites More sharing options...
