LarryBC Posted June 5, 2024 Share Posted June 5, 2024 I'm using a very old edition of Chief Architect (X1 from 2007). After starting to suspect some dimension problems, I drew a plan 100' x 50' containing no interior dividing walls. Outer walls are 1' thick. Since wall dimensions are defaulted to surfaces, I expected Living Area to show as 5000 sq. ft. However, it shows 5163 sq. ft. Don't know whether there's a setting I may have somehow overlooked, there's a bug in the program or it just aged out of reliability. Thanks for your ideas for a possible solution. Link to comment Share on other sites More sharing options...
JiAngelo Posted June 5, 2024 Share Posted June 5, 2024 Any chance you are measuring room area to surface materials vs wall face? 51' 1" x 101' 1" = 5163sf. 6.5" of exterior materials like brick/stone and an air gap? 2 Link to comment Share on other sites More sharing options...
raltd9245 Posted June 5, 2024 Share Posted June 5, 2024 39 minutes ago, JiAngelo said: Any chance you are measuring room area to surface materials vs wall face? 51' 1" x 101' 1" = 5163sf. 6.5" of exterior materials like brick/stone and an air gap? I'm old school I do it by hand and draw rectangles. Link to comment Share on other sites More sharing options...
Solution TeaTime Posted June 5, 2024 Solution Share Posted June 5, 2024 In my experience the program is never (rarely?) wrong in these calculations, it's just sometimes unclear what is being calculated, or how. I have no idea if X1 had this but I assume it did, but a Living Area polyline will show you exactly what's being calculated. They have an article on this: https://www.chiefarchitect.com/support/article/KB-00424/understanding-how-the-square-footage-or-living-area-is-calculated.html 2 Link to comment Share on other sites More sharing options...
LarryBC Posted June 5, 2024 Author Share Posted June 5, 2024 Thanks, TeaTime. That article answered my question. Measurements are from the main layer of external walls rather than the surface. In the old version I have, there's no way to change the setting to the actual inner surfaces as shown in the article. If I draw the same 100' x 50' outline using interior walls instead of exterior, the area correctly displays as 5000 sq. ft. Thanks to JiAngelo as well. Link to comment Share on other sites More sharing options...
