Gary-Doski Posted June 5, 2024 Share Posted June 5, 2024 I can't seem to get x16 to render without crashing, attached bug report. Link to comment Share on other sites More sharing options...
ericepv Posted June 5, 2024 Share Posted June 5, 2024 This is often caused by an out of date video card driver. Check to make sure you have the latest update. Link to comment Share on other sites More sharing options...
DBCooper Posted June 5, 2024 Share Posted June 5, 2024 A "device removed" message is almost always a video card problem. Chief has a tech article that should help: https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems-in-chief-architect.html If all else fails, then you will probably want to call tech support. Link to comment Share on other sites More sharing options...
Gary-Doski Posted June 13, 2024 Author Share Posted June 13, 2024 (edited) Thanks for the input guys, I have a Radeon RX 6700 XT drivers are up to date. Now X16 is crashing every time I try to open any dialog box. Same error code Turns Out I do have an issue with my Video driver?? stay tuned.... Edited June 13, 2024 by Gary-Doski New Info Link to comment Share on other sites More sharing options...
Gary-Doski Posted June 13, 2024 Author Share Posted June 13, 2024 So, I had the current video driver, but it was not install correctly, fixed that, all good, I'll stop blaming Chief, but in my defense, X15 worked fine? Great support at Radeon!! Link to comment Share on other sites More sharing options...
