IRDesign Posted June 3, 2024 Share Posted June 3, 2024 Why wouldn't my cabinet hardware be showing in elevations or 3d view?? They are clearly in there. Showing on a couple cabinets/drawers, but not all. Link to comment Share on other sites More sharing options...
DBCooper Posted June 3, 2024 Share Posted June 3, 2024 Could be a few things... Maybe the symbol is messed up? Try taking a cross section view to see if it is embedded in or behind the door. Maybe it's not really a door? If it's a "door panel" or "end panel" it won't have hardware. For other things you might need to post the plan. Link to comment Share on other sites More sharing options...
IRDesign Posted June 4, 2024 Author Share Posted June 4, 2024 I still can't figure it out... Here is the plan. Varela_Final Concept.zip 1 Link to comment Share on other sites More sharing options...
TeaTime Posted June 4, 2024 Share Posted June 4, 2024 Your zip file contains a 0kb plan file, usually this happens when the plan is still open in Chief when you zip it. Close Chief and try again. Link to comment Share on other sites More sharing options...
DBCooper Posted June 5, 2024 Share Posted June 5, 2024 Ok, I have a new guess. Your wall cabinet is using an actual door and not a panel otherwise you would not see the opening indicators. My bet is that you have setup the handle for the cabinet but that your particular door is set to "none" for some reason. There are two different ways to set hardware (and door styles) for cabinets. If you set it up on the "door/drawer" page, you are setting up the "main style" to use for that cabinet. If you select any door, and then use the "specify" button, you can override the settings for any particular face item. This is what you do if you want a cabinet with multiple doors to have different styles for the doors or hardware. It's pretty easy to override the settings for a particular door by just "painting" the door or hardware from the library. You can also get them into all kinds of different states using the match properties tool or style palettes. You should be able to open the dialog, click on the door, click on "specify", and in the "door face item" dialog make sure the door and handle are both set to "use default". If it's not this, then you need to post a plan file for someone to take a look at. And, like TeaTime said, make sure you close Chief when you try to zip the file. Link to comment Share on other sites More sharing options...
