Floor 3 label to Floor 2.5?
cbucks
Negative, there is no renaming floor numbers in the programs interface. Rely instead on how you label the printed pages on your Layout page rather than what the program is saying the floors technically are. No one's going to see the Floor number in the program but you.
If you use "Saved Plan Views" and name them in the Project Browser, then you can use the Atomatic Label as the label of the Callout Boxes in Layout.
Note that Chief uses "Floor Level" simply as an identifier.  It's not intended to be the name of the floor.
