Cadwork22 Posted May 7, 2024 Share Posted May 7, 2024 Is it possible to have 14' walls and 12' ceilings. Thanks, Link to comment Share on other sites More sharing options...
DBCooper Posted May 7, 2024 Share Posted May 7, 2024 Yes. See this tech article: https://www.chiefarchitect.com/support/article/KB-01050/creating-and-framing-a-dropped-ceiling.html Link to comment Share on other sites More sharing options...
Cadwork22 Posted May 7, 2024 Author Share Posted May 7, 2024 I was able to create taller walls with a dropped ceiling, however the roof is doing this. See attached. Link to comment Share on other sites More sharing options...
Cadwork22 Posted May 7, 2024 Author Share Posted May 7, 2024 Is there a wall to roof tool in chief? Link to comment Share on other sites More sharing options...
TeaTime Posted May 7, 2024 Share Posted May 7, 2024 There's a couple things that could be happening here, but walls should never stick through roof planes like that, they should automatically cut down to fit under the roof. I would assume that in your attempts to get this to work, you've manually pulled the tops of your walls up to the desired height, locking them at that height. Open your walls and look at the Structure panel, make sure that Default Wall Top is checked. Link to comment Share on other sites More sharing options...
Cadwork22 Posted May 7, 2024 Author Share Posted May 7, 2024 I pulled the wall up above the roof, can I use the roof plane to cut the wall as needed. Link to comment Share on other sites More sharing options...
Cadwork22 Posted May 7, 2024 Author Share Posted May 7, 2024 nice thanks! 1 Link to comment Share on other sites More sharing options...
TeaTime Posted May 7, 2024 Share Posted May 7, 2024 2 minutes ago, Cadwork22 said: I pulled the wall up above the roof yeah, generally speaking, don't do this. Walls know where they're supposed to go, let them do their thing and you'll be better off. I only ever adjust walls in 3D/Section views if nothing else seems to work, but don't make a habit of it. Link to comment Share on other sites More sharing options...
Cadwork22 Posted May 7, 2024 Author Share Posted May 7, 2024 thanks, appreciate it! Link to comment Share on other sites More sharing options...
Cadwork22 Posted May 7, 2024 Author Share Posted May 7, 2024 Is there a way to add attic vents on the roof plane? So far only being able to find vents that position in attic floor. Link to comment Share on other sites More sharing options...
Solution DBCooper Posted May 7, 2024 Solution Share Posted May 7, 2024 If you look in the library under mechanical, ventilation, there is a folder called "roof vents" where you should find some that might work for you. Link to comment Share on other sites More sharing options...
Cadwork22 Posted May 7, 2024 Author Share Posted May 7, 2024 awesome thanks Link to comment Share on other sites More sharing options...
