SQFT
Cadwork22
Go to solution Solved by Chopsaw,
  • Solution
2 hours ago, Cadwork22 said:
I did what you said, however its only working on the second floor, how can I get it displayed for both floors?
It seems maybe there is still a quirk with that and this has to be the oddest work around ever imaginable.  Try running "plan check" and see if that resolves the issue. ;)
Chief says "total" but the labels report total for all rooms included in the floor displayed, for which that radio button is checked.
A two-floor house, 1500 sf each floor, will show 1500 sf living area in a label on the plan view of each floor, two separate plan views, floor 1, and floor 2, but nowhere (unless you can show me what I am missing) is 3000 sf reported in a label.
I think you are working with one-floor plans.
