Joe_cul Posted April 27 Share Posted April 27 Something under my building. Of course it shows up everywhere. Can't highlight it to open it. Tried in elevations, crosscuts. Can't find it on a plan drawing. It is the same as the floor in the crawl space. 4" dirt with poly on top. It is 30" lower than the floor. Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 27 Share Posted April 27 Might want to post the plan. If they are directly under the walls, and you never manually drew them they may be footings. Link to comment Share on other sites More sharing options...
javatom Posted April 27 Share Posted April 27 You might have the room definition set to DECK and it is generating the supports and footings. Try changing the room definition to something else and see if it goes away. Link to comment Share on other sites More sharing options...
