Window help. Have many views open, want to see two only, tiled horizontally
GeneDavis
The only way is to drag the views you want into the corners...or top/bottom.
There isn't a hotkey to tile just specific views...it's all or nothing using F6. You can use F6 and then close the views you don't want to see...but, then you lose the view. So...I guess that's not a great solution.
