Pony Walls Question
Cadwork22
Go to solution Solved by ericepv,
If I understand you correctly, you want to use a half wall which is just a solid railing. Either use the 'Half Wall' option from the 'Build Wall' tool or just make your existing wall a railing by checking 'Railing' in the 'General' section of the DBX for the wall and then in the 'Rail Style' tab, check 'Solid' in the 'Specify railing ' section.
  • Solution
Just do it as a railing. Specify the height in the 'Newels/Balusters' tab and in the 'Rail Style' tab, select 'Solid' and in the 'Wall Types' tab select a block wall.
