GeneDavis Posted April 18, 2024 Share Posted April 18, 2024 I gotta finish this thing today, and this one is stopping my progress. See the pic, attached. The truss TR-9 won't draw all the way to the subfascia. The red line is where I want to pull it but it won't pull past the hip. Help! Properly drawn, I'll then pull TR-11 and TR-5 to connect to TR-9. Here is the file. 85 mb but this should work. Doering.plan Link to comment Share on other sites More sharing options...
tundra_dweller Posted April 18, 2024 Share Posted April 18, 2024 @GeneDavis The only way I can get it to kind of work is to drop the top chord to 5" instead of 5 1/2". Anything over that and it stops short and you have to pull another truss from the subfascia to butt up to the end of TR-9 to fill that gap, if using a 5 1/2" top chord. Link to comment Share on other sites More sharing options...
robdyck Posted April 18, 2024 Share Posted April 18, 2024 It worked for me: changed the top chord to 3.5" select the fascia, single click extend object, click on tr-2 Link to comment Share on other sites More sharing options...
robdyck Posted April 18, 2024 Share Posted April 18, 2024 To go back to a 2x6 top chord: open truss tr-2 dialog select 'Lock Truss Envelope..." change top chord back to 5 1/2" select 'Force Truss Rebuild" Link to comment Share on other sites More sharing options...
tundra_dweller Posted April 18, 2024 Share Posted April 18, 2024 Yep, Rob's method works! Link to comment Share on other sites More sharing options...
GeneDavis Posted April 18, 2024 Author Share Posted April 18, 2024 Thanks, everybody! Link to comment Share on other sites More sharing options...
