DanielleDubuc Posted April 15, 2024 Share Posted April 15, 2024 Hi, When I send a layout to the printer I get a warning telling that "Printer DPI value is low: 96 DPI". When I try to modify the DPI value, there is nothing else thant 96 in the drop down menu. But when I send the plan file of the same drawing to the same printer, I get 600 DPI. Can someone tell me if there is a way to set the layout printing to a higher DPI? Thanks in advance Link to comment Share on other sites More sharing options...
MPDesign Posted April 15, 2024 Share Posted April 15, 2024 Hi Danielle, Try using "Chief Architect save as PDF" in the printer dropdown. then print the pdf to your printer. Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 15, 2024 Share Posted April 15, 2024 that is interesting, I would submit that to CA, one would think the available DPI would not be contingent on layout vs plan Link to comment Share on other sites More sharing options...
DanielleDubuc Posted April 16, 2024 Author Share Posted April 16, 2024 11 hours ago, MPDesign said: Hi Danielle, Try using "Chief Architect save as PDF" in the printer dropdown. then print the pdf to your printer. This is a good suggestion Michael, it's what I currently do. But I would really like to print right from the layout and save a little time. Thanks for the suggestion. Link to comment Share on other sites More sharing options...
DanielleDubuc Posted April 16, 2024 Author Share Posted April 16, 2024 8 hours ago, SHCanada2 said: that is interesting, I would submit that to CA, one would think the available DPI would not be contingent on layout vs plan SHCanada2, I will do that. Thank you! Link to comment Share on other sites More sharing options...
DanielleDubuc Posted April 16, 2024 Author Share Posted April 16, 2024 Can anyone tell me where I can find the email address for the tech support please. I've been looking for it but coudn't find anything. Or else, is ther any way I could tag the tech support on this post? Thanks in advance! Link to comment Share on other sites More sharing options...
