3dsDan Posted April 9, 2024 Share Posted April 9, 2024 Can someone please help me. Why is the door showing up with a space under it when I set the "from finish floor to bottom" offset to zero. When I change this figure to something like 1/8" it then creates a white portion where the threshold would be even though this is turned off and also Z fighting with my floor finish at the exterior wall face. Did not have this issue with x14. Link to comment Share on other sites More sharing options...
DBCooper Posted April 9, 2024 Share Posted April 9, 2024 According to your picture, that's an interior door but not sure that matters in this case. You might want to check the rough opening settings and if that doesn't help you will probably need to post the plan. Link to comment Share on other sites More sharing options...
Doug_N Posted April 10, 2024 Share Posted April 10, 2024 Dan, Please post the plan file. I am very curious about how this is happening. Link to comment Share on other sites More sharing options...
3dsDan Posted April 13, 2024 Author Share Posted April 13, 2024 I have attached the plan file for this issue that seems to be in x15 for it does not exist in x14 or x13. I have notice that it came with the new specification Panel Size (label 2) in x15 door specification panel. This happens when I have my finish floor to bottom set to 0 (label 1), if I change this to maybe 1/16 it then adds a bottom casing below the door as well as a white box which appears like a threshold, but it is not. I have attached an image of the setting box indicating some of my settings. Door Issue.plan Link to comment Share on other sites More sharing options...
DBCooper Posted April 14, 2024 Share Posted April 14, 2024 Take a look at the cross section view. That is the floor slab under the door. In X14, the floor would butt into the stem wall and in X15 the stem wall is lower and floor slab builds on top of it. It is really only noticeable because you painted your concrete walls blue and your floor slab is still grey. I don't know if there is a way to make the floor slab work the same way that it did in X14 but you can change the floor slab to use a concrete material that is blue instead of grey. Link to comment Share on other sites More sharing options...
