Leadcarpo Posted April 4, 2024 Share Posted April 4, 2024 Hello, I am curious if a macro can be used in an elevation camera and layout callout, to specify the room name and cardinal direction. The hope is that this will automatically name the camera and put the name on the callout. I have been able to get the label to generate on the callout when I name the camera, but I am just trying to stream line anything I can, example below, thanks in advance! Kitchen - North Wall Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 4, 2024 Share Posted April 4, 2024 the other thing you can do is just have a bunch of named cameras on your template, and then only use the ones you need Link to comment Share on other sites More sharing options...
tpeck23 Posted April 4, 2024 Share Posted April 4, 2024 @Leadcarpo Really if you want to streamline and have this macro as well you may want to look into getting with @Renerabbittand his templates. My life got smooth and easy with his Pro plan template and pro layout templates. you can check out his discord server as well https://discord.gg/UHcqK3yZ Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 21, 2024 Share Posted May 21, 2024 On 4/4/2024 at 7:58 PM, SHCanada2 said: the other thing you can do is just have a bunch of named cameras on your template, and then only use the ones you need Expand this^ Leadcarpo messaged me direct, thank you @tpeck23 response was you would need a custom north point. Would suggest everyone put a plus one on Other response was just switch to "left right" instead of east west and save those in template. Link to comment Share on other sites More sharing options...
