Need advice on how to do this the easiest way possible
DH7777
We have a 4plex that we build a lot and I am task to create color renderings for the planning department when the y request them. The city planning department here is now wanting us to build this 4plex into a 5plex. So My company wants to remove one unit on one end, leave the two story in the middle and copy/mirror the other two units from the other side and place them where I removed the one unit. I am not sure how to do this quickly without finding myself just rebuilding the whole thing. Trying to figure out how I can make a block out of the two units I need to mirror and then fudge it into its new position. But If anyone has an idea of how you would attempt to make this change the fasted please let me know. Thanks!
Attached are some pics of what I need to do. i will follow up with the plan.file next because it is not letting me upload it with these pics due to max 14mb limit
I had a similar situation with some townhouse units awhile back. As I recall, it involved  a lot of cut and paste. Take a look at this article from the Knowledge Base (scroll down to 'To copy and reflect a structure') https://www.chiefarchitect.com/support/article/KB-00284/using-the-reflect-about-object-tool.html
Expand
Okay thanks
Expand
I do these a lot.
Create a mirror version of the plan:
1) turn on all layers except cameras and use the "Edit" > Edit Area > Edit Area All Floors and marquee select everything.
2) transform/replicate > reflect horizontally
Save as Mirrored Version.
3) Delete everything on the right side after that dividing wall.
4) Edit Area All Floors, select all and move the block to the right by the appropriate amount.
5) Edit Area All Floors, select all and copy (ctrl C)
Open original plan and delete everything to the left of that dividing wall.
6) Paste Hold Position.
7) Profit
