JWPrendergast Posted March 28, 2024 Share Posted March 28, 2024 I have the auto foundation turned on which I like because as I adjust the main floor, the basement footprint matches it. I'd like to turn off the foundation under the garage and porch; any idea how to do that while leaving the auto rebuild foundation tool on? Link to comment Share on other sites More sharing options...
SNestor Posted March 28, 2024 Share Posted March 28, 2024 Once your foundation is built and "auto rebuild" is still turned "on"...if you want to change a specific "room" on the foundation level you will have to turn auto rebuild off. It's not really a big deal...you can always rebuild your foundation again (or manually move walls into position)...and then modify the rooms as needed..again. This is why it's a good practice to not build the foundation until you have the main level floor plan as you want it. Below is a screen clip of a test plan I just did in X15...you will see the porch is basement depth. This is because you can only preset the basement depth...and the depth of the garage walls. Chief treats your porch "rooms" as basements. Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted March 28, 2024 Solution Share Posted March 28, 2024 Open the Garage and Porch Rooms up on Floor 1, click on the Structure tab, and under Floor, uncheck Build Foundation Below. 1 Link to comment Share on other sites More sharing options...
JWPrendergast Posted March 29, 2024 Author Share Posted March 29, 2024 Both great ideas but Alaskan_son's was exactly what I was trying to do. Thanks! Link to comment Share on other sites More sharing options...
