GeneDavis Posted March 26 Share Posted March 26 I post a q about an issue, someone properly says post the plan. I check file and it's 50 Mb. I can't go cloud 'cause I have no cloud accounts. What's the quick way to scrub the stuff unimportant to Chief building? Link to comment Share on other sites More sharing options...
Christina_Girerd Posted March 26 Share Posted March 26 My method is to select a layerset that is part of all my plans and is descriptively named "All Off Layerset." So I turn on this blank layerset then I first turn on layers that tend to add a lot to the file size - plants, interior accessories, furniture, vehicles, images - things that usually aren't needed for posting problem plans and then delete that stuff after briefly looking it over to make sure something I might need didn't get accidentally put on a wrong layer. And of course, this is after I'd saved the file as whatever the title was with some descriptor like "2024 03 Smith Plan for posting." Then I check the new file size. If I need to reduce more, I next typically consider deleting layers for terrain, fencing, exterior furniture, fancy lighting etc, depending on what I needed to show the problem. Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 26 Share Posted March 26 11 hours ago, GeneDavis said: I can't go cloud 'cause I have no cloud accounts. Up to 2gig free with online wetransfer https://wetransfer.com Link to comment Share on other sites More sharing options...
RobDesLLC Posted March 26 Share Posted March 26 You have Dropbox noted in your signature. Can you not share a compressed folder from Dropbox? Link to comment Share on other sites More sharing options...
GeneDavis Posted March 26 Author Share Posted March 26 Thanks @Michael_Gia! I joined WeTransfer and will use the free version for occasional uploads such my issue as re cabinet display in another thread here. @RobDesLLC I will edit my sig line to delete Dropbox, which I do not use any longer. Tried it long ago and never fully understood its operation. Link to comment Share on other sites More sharing options...
